When hatching surfaces I am getting artefacts around some of the edges. These seem to vary in size and are particularly intrusive on one drawing.
I suspect that the problem may have to do with the way I have set up my dimensions as the hatching in question needs to be at a very low scale to look right:
AR-RSHKE at 0.0007 scale.
I attach a sample drawing and a pdf printout.
Artefacts round hatched surfaces
- Vest_mTak.pdf
- (126.39 KiB) Downloaded 402 times
- Vest.dwg
- (39.49 KiB) Downloaded 400 times
Re: Artefacts round hatched surfaces
Thanks for your report and files.
This is related to bug #1101 and has been fixed for the next release:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1101
For now, you can change the point display mode, for example to invisible:
Edit > Drawing Preferences > General > Point Display
Thank you very much for your response.
BR
Marius
BR
Marius
I have tried setting the point display in drawing preferences to Mode:1, Size:0 (invisible). The problem is reduced but not altogether solved (please see .pdf printout of affected drawing).
When can we expect the version with a fix for this?
Best wishes
Marius
Best wishes
Marius
- D_107_Nord.pdf
- .pdf with artefacts around roof hatching.
- (178.08 KiB) Downloaded 388 times
The next release (3.7.0) is scheduled for later this month.
Thanks Andrew. I now have 3.7.0
