Drawing a Line with a Given Length
Post by andrew » Fri Nov 14, 2014 3:32 pm
There are several ways to draw a line with a certain length.
If you also know the angle of the line in degrees, you can use the line with angle tool:
Draw > Line > Line from Angle
1. Enter the angle and length of the line
2. Place the line in the drawing
If the angle is not known as value but rather visible in the drawing, you can use the regular line tool:
Draw > Line > Line from 2 Points
1. Click the start point of the line
2. Click the "Restrict Angle or Length" button in the options tool bar:
Screen Shot 2014-11-14 at 15.09.56.png (14.5 KiB) Viewed 19775 times
3. Enter the desired length in the options tool bar:
4. When placing the end point of the line now, the line automatically has the desired length (or a multiple thereof):
Screen Shot 2014-11-14 at 15.17.35.png (150.23 KiB) Viewed 19775 times
Another way is to draw the line with the wrong length first and then use the property editor to adjust the length:
Screen Shot 2014-11-14 at 15.29.45.png (164.65 KiB) Viewed 19775 times
There are also other ways to specify a length of a line, for example by trimming, trimming by a given amount, entering the end coordinates relative to the start point, etc.
Moderator
Re: Draw line with given length
Post by Clive » Mon Nov 17, 2014 2:31 pm
In addition, you can also use the Horizontal and Vertiacl Line tools, just enter the required length in the 'Length' field :D .
Horizontal and Vertical Lines.png (19.07 KiB) Viewed 19633 times
