How do I force CAM to set gcode on every line
qharley
Post by qharley » Mon Jan 19, 2015 11:32 am
I am using the following option
// always write G-code, even if it is the same as on the previous line:
this.alwaysWriteGCode = true;
but it seem to disregard this setting. Some lines following a G1 command only has coordinates, and even that is acceptable in most CNC machines, mine require a Gcode on every line.
How do I fix this?
Re: How do I force CAM to set gcode on every line
Post by andrew » Mon Jan 19, 2015 11:36 am
Please attach the complete configuration you are currently using (.js file), thanks.
qharley
Post by qharley » Mon Jan 19, 2015 12:42 pm
Attached
ruijie.js
(3.25 KiB) Downloaded 418 times
qharley
Post by qharley » Mon Jan 19, 2015 12:45 pm
Here is a gcode file created by it:
Power_Con_channel.gcode.txt
(887 Bytes) Downloaded 415 times
Post by andrew » Mon Jan 19, 2015 2:49 pm
Please add the following lines to your configuration:
ruijie.prototype.gotModeChange = function(m) {
    return true;
qharley
Post by qharley » Mon Jan 19, 2015 3:24 pm
Does not work yet...
G21
G92 X0 Y0
G0 F20000
G1 S0.8
G1 F800
G00 Y-10
M3
G4 P200
G01 Y-60
X270
Y-10
X0
M5
G00 Y48
M3
qharley
Post by qharley » Mon Jan 19, 2015 3:27 pm
Current workaround is to manually add the G0 and G1 into the lines.
What else can I try?
Post by andrew » Mon Jan 19, 2015 3:34 pm
I cannot reproduce this. I'm using your exact configuration from above with the additional three lines I've posted.
Common mistakes are:
- QCAD/CAM not restarted after changing configuration
- Looking at the wrong output data (old version of a file, wrong file)
qharley
Post by qharley » Mon Jan 19, 2015 5:04 pm
Thank you. Working perfectly after actually saving the 3 extra lines into the .js file...
Go figure.
:oops:
Post by andrew » Mon Jan 19, 2015 5:13 pm
qharley wrote:Thank you. Working perfectly after actually saving the 3 extra lines into the .js file...
Ah, yes - another classical one :) This happens to everyone. Glad it works now!
