When i want to selecting a bunch of lines, one at time, it will not happen. When i select
a second line, the fist will deselect.
Same thing happens when i select patch of features and then select a second patch of
features, the first patch of features deselects.
Is there a way to turn off the auto deselecting?
much appreciate any help.
k-
Auto deselecting of lines
Re: Auto deselecting of lines
Click the first line and before you click the next line press and hold the "Shift" Key on your Keyboard. After clicking the line you can release the shift key. This will include or exclude the next clicked line. Play with it ...keghn wrote:When i want to selecting a bunch of lines, one at time, it will not happen. When i select
Have a closer lock on "Menu / Selected" or switch the Toolbar "Select" visible (Menu/View/Toolbars).keghn wrote: Same thing happens when i select patch of features and then select a second patch of
There are many possibility's to choose from.
This is an QCAD Reference Manual Link for an older Version - maybe you like to check it out to have an idea what you can do.
http://www.ribbonsoft.com/doc/qcad/2.2/ ... ter27.html
Most of the advanced selection tools offer options to replace the current selection, add to the current selection, remove from selection or intersect with the current selection:
http://qcad.org/doc/qcad/latest/referen ... doc/Select
Ok, i got it now.
appreciate the expertise, here.
