Setting for creating rectangle
JulesB
Post by JulesB » Wed Jan 28, 2015 3:40 am
Hi all,
Is there a setting you can apply to a drawing that will automatically turn any rectangle you draw into a polyline rather than four separate lines :?:
Jules
Re: Setting for creating rectangle
Post by Husky » Wed Jan 28, 2015 8:29 am
Hello Jules,
JulesB wrote:Is there a setting you can apply to a drawing that will automatically turn any rectangle you draw into a polyline rather than four separate lines :?:
No, not that I know. :(
But - you can use the "Create from Segments" tool (below Draw, Polyline). Much faster than the single segment selection. :wink:
Moderator
Post by Clive » Wed Jan 28, 2015 9:56 am
Hi Jules
If you are creating Rectangles using the 'Shape Tools' there is a check-box you can tick to 'Create Polyline' from all the rectangles you draw using this tool!
JulesB
Post by JulesB » Thu Jan 29, 2015 2:38 pm
Thanks for your replies guys, much appreciated :)
Clive could you clarify where you find shape tools... is it under the draw menu?
Moderator
Post by Clive » Thu Jan 29, 2015 4:54 pm
JulesB wrote:Clive could you clarify where you find shape tools... is it under the draw menu?
Here we go -
Yes Draw > Shape
Shape Tools.png (7.79 KiB) Viewed 6338 times
JulesB
Post by JulesB » Sun Feb 01, 2015 9:57 pm
Thank you Clive, sorry I didn't see it for some reason :oops:
