How do I change object length without changing width ?
Rochus
Post by Rochus » Fri Jan 30, 2015 4:08 pm
Let's say I have already a rectangle 2 cm x 10 cm, can I just change the current length to 15 cm without changing the width and redrawing completly my rectangle ?
Thanks.
Re: How do I change object length without changing width ?
Post by andrew » Fri Jan 30, 2015 4:17 pm
Note that a rectangle object does not exist in QCAD / CAD in general.
A visual rectangle in your drawing may consist of
- four loose lines
- a single polyline with four segments
- a block reference containing the four lines or the polyline
In the first two cases, you can extend the length of the rectangle using the stretch tool:
http://qcad.org/doc/qcad/latest/referen ... oc/Stretch
In the last case (block reference), you might be able to use the block scale factors (block reference properties), depending on your exact block definition.
