Can't add to library
nofate
Post by nofate » Thu Feb 12, 2015 5:24 pm
Using version 3.7.7 on Windows 7. I have followed the tutorials, but I can't add new components that I create to either the architecture library or line types library. When I try to save a block I get a message that it can't open file C:/Program Files (x86)QCAD/libraries/default/range.dfx . I draw a component such as top view of a kitchen range, block it, select a reference point and try to save it in the appropriate library directory, but so far no success.
What am I doing wrong?
Re: Can't add to library
Post by Husky » Thu Feb 12, 2015 7:46 pm
Hi nofate,
try this one:
Draw your component,
select the component,
Now select the "Create Library Item" tool below: Menu / Block
Chose the Referenspoint of your selection,
Save as in the proper directory (one of your Library Sources)
Open the Library Browser,
Update DB from File System
Use the new Library Item ....
