How do I add new fonts?
Danc
Post by Danc » Tue Mar 10, 2015 5:11 am
How do I add new fonts or convert .ttf to .cxf?
Re: How do I add new fonts?
Post by andrew » Tue Mar 10, 2015 8:47 am
Let me ask about your motivation for doing this first since QCAD 3 comes with full support for TrueType fonts built in. Thanks.
Danc
Post by Danc » Tue Mar 10, 2015 9:22 pm
how do I add a new true type font? When i put a .ttf in the fonts file it doesn't show up in the drop down box. if I can use TrueType Fonts I guess there is no reason to convert. I am just having a hard time figuring it out. Thank you
Post by andrew » Tue Mar 10, 2015 10:08 pm
TrueType fonts must be installed system wide to be used with QCAD (or any other application).
Post by Husky » Tue Mar 10, 2015 11:15 pm
Danc wrote:... a .ttf in the fonts file it doesn't show up in the drop down box.
Please check also which font has to be displayed in the selection box.
Edit / Application Preferences ...
Danc
Post by Danc » Wed Mar 11, 2015 1:56 am
That was it I didn't have the font installed to the computer. Thank you!
