[solved] Hidden Detail
amanabove
Post by amanabove » Thu Mar 26, 2015 10:49 am
Andrew, I have another question for you: Is there a way I can draw in broken lines (for hidden detail, etc)? Is there already a function for this under DRAW that I'm overlooking?
Thanks.
Re: Hidden Detail
Post by andrew » Thu Mar 26, 2015 10:54 am
If I understand you correctly, you are looking for a way to control entity attributes (line color, line type, line weight).
Please refer to this thread in the tips and tricks section:
viewtopic.php?f=47&t=3202
amanabove
Re: Hidden Detail
Post by amanabove » Sat Mar 28, 2015 2:24 pm
Thanks very much, Andrew. That did the trick.
