Re scaling an existing drawing
thumbtac
Post by thumbtac » Sun Mar 29, 2015 8:59 pm
Ver 3.9.9.0
Build Mar 9 2015
Qt Ver 4.7.4
Compiler MSVC++10.0 (2010)
OS Win 8.1 64 bit
When I change the scale of a drawing, can I have the dimensions change? For example, if I have a square with the dimensions of 100mm x 100mm, when I scale it by a factor of 2, will the new drawing now show the dimensions as 200mm x 200mm? Could anyone please explain how to go about this,
Re: Re scaling an existing drawing
Post by Husky » Mon Mar 30, 2015 7:33 am
thumbtac wrote:When I change the scale of a drawing, can I have the dimensions change?
Yes!
Select the whole drawing or just a part of your drawing,
Pick the "Scale" tool,
chose a convenient reference point,
Scale dialog: Factor 2 - hit ok - done.
Note: Is in your selection a dimensioning - it will recalculate the dimension text by itself. In this case 100 will change to 200.
Dimensioning before or after you scale the drawing doesn't matter - it works either ways,
Is your dimension text for any reason "exploded" by you - the function of the dimension text isn't working anymore,
thumbtac
Post by thumbtac » Mon Mar 30, 2015 8:10 pm
Thank you for your help. Things work as you suggest on any drawing that I have done in QCAD, however if the drawing has been imported from another source then it does not appear to work. The selection will double in size if the selected scale factor is 2 but the dimensions remain as per the original. I have not used the explode command. I am a beginner with this program and am grateful for any assistance, I have purchased the book QCAD Introduction to CAD but it is of no help in this instance.
thumbtac
Post by Husky » Tue Mar 31, 2015 7:28 am
thumbtac wrote:... however if the drawing has been imported from another source then it does not appear to work. The selection will double in size if the selected scale factor is 2 but the dimensions remain as per the original.
This Info was missing for my answer. :wink:
However - if the source Program is not using the same functionality (programming) as QCad for dimensioning it could / will fail. Maybe you need to replace for extern drawings the dimensioning in QCad to get the same benefit of it as expected.
