Save Application Prefs to share with others?
Did a quick look for a configuration file of some sort but didn't find anything. Is their a way to save the Application Preferences so I can share with other users?
Re: Save Application Prefs to share with others?
Windows XP:
C:\Documents and Settings\username\Application Data\QCAD\QCAD.ini
Windows Vista, Windows 7:
C:\Users\username\AppData\Roaming\QCAD\QCAD3.ini
Unix / Linux / Mac OS X:
~/.config/QCAD/QCAD3.ini (or .conf)
See also:
http://www.qcad.org/en/qcad-documentati ... leshooting
See also:
Thanks Andrew! I did not look in that section.
