Dimensions not appearing
michaelbajko
Post by michaelbajko » Thu Jun 04, 2015 4:21 am
When trying to create Dimensions all I get is a line. No arrows, no text.
Win 8.1 64 qcad 9.3.9 Cheers!
Re: Dimensions not appearing
Post by Husky » Thu Jun 04, 2015 7:54 am
Hi michaelbajko,
please attach an example drawing - thats the easiest way to see what is going on. Thanks!
Moderator
Post by Clive » Thu Jun 04, 2015 8:59 am
Main Menu > Edit > Application (or 'Drawing Preferences', applies to the current drawing only!) > Defaults for new drawings > Dimension settings
and check to see if you have any values in the fields - Text height, Arrow size etc....
michaelbajko
Post by michaelbajko » Thu Jun 04, 2015 3:26 pm
~belt_Elevation02 - Copy.dxf
(123.73 KiB) Downloaded 350 times
thanks for your replies.Dimension preferences all OK. Drawing attached with text and arrow free vertical dimension lines
Moderator
Post by Clive » Thu Jun 04, 2015 4:03 pm
Untick the check box and adjust the values to suit what you need.
*Good practice would be to set up dedicated layers for outlines, dimensions etc..
michaelbajko
Post by michaelbajko » Fri Jun 05, 2015 1:44 pm
Thanks so much for your replies, much appreciated, unfortunately same result when recommendations implemented. :(
Post by andrew » Fri Jun 05, 2015 1:56 pm
1. Load the drawing
2. Edit > Drawing Preferences (NOT Application Preferences!) > Dimension > Dimension Settings
3. Enter a dimension Size Scale Factor, e.g. 20:
Screen Shot 2015-06-05 at 14.55.26.png (149.27 KiB) Viewed 5726 times
4. OK
michaelbajko
Post by michaelbajko » Sat Jun 06, 2015 7:08 pm
Done! Many thanks Andrew et al! :D
