[solved] Save and Retrieve files from other harddrives
A. Groot
Post by A. Groot » Mon Jul 20, 2015 6:36 pm
Hello
Operating system Ubuntu 14.04 64 bit
intel pc 64 bit, ssd master disk and other data drives
QCAD 3.9 64 bit version
Question: I am not able to view my other data drives, then my ssd drive in the file "save" and "Open" window's.
Also no option to write a location in the filename sub window
pse advise
regards Louis
Re: Save and Retrieve files from other harddrives
Post by andrew » Mon Jul 20, 2015 7:02 pm
You can likely find your external drives mounted under /media.
A. Groot
Post by A. Groot » Tue Jul 21, 2015 10:24 pm
Thanks, problem solved !
regards Louis
