Is it possible to have QCAD execute scripts to produce drawings? How about from C++ using the API? I mean, by not even running QCAD's graphical interface. I googled for the answer to that but only found stuff about writing plugins.
Further searching, I found an example of doing this in javascript: http://www.qcad.org/doc/qcad/latest/dev ... awing.html
Is there an example in C++? Using Qt, I guess.
scripting qcad?
Re: scripting qcad?
Yes, have a look at the 'merge' command line tool included with QCAD consisting of:
- the launcher bash or batch scripts: merge / merge.bat
- the implementation in ECMAScript (JavaScript): scripts/Tools/MergeDrawings
Re: scripting qcad?
OK. I can use javascript if I have to, but is there a C++ example?
Re: scripting qcad?
No. JavaScript is the way to go.bobself wrote:but is there a C++ example?
You can write plugins in C++ provided you are using the same Qt version, compiler and compiler version we're using. Using the script interface is certainly far less painful.
