Changing the ruler number format
Post by andrew » Thu Jul 30, 2015 7:33 pm
From a QCAD user:
How can I change the ruler display format from engineering (12.34) to imperial (1'-5/16") units?
Re: Changing the ruler number format
Post by andrew » Thu Jul 30, 2015 7:38 pm
First, make sure that your drawing unit is set to Inch under:
Edit > Drawing Preferences > General > Drawing Unit
Screen Shot 2015-07-30 at 20.30.06.png (80.08 KiB) Viewed 2631 times
All measurements in QCAD are displayed in the format defined under:
Edit > Drawing Preferences > Dimension > Dimension Settings > Label Format > Linear Dimensions
Screen Shot 2015-07-30 at 20.32.40.png (138.65 KiB) Viewed 2631 times
