aligning holes
aklweld
aligning holes
Post by aklweld » Wed Sep 02, 2015 5:23 am
Hi
im having a bit of trouble drawing the holes I need on the attached part, I have been able to do the vertical and horizontal ones but I cant figure out how put the holes on the angled section of the job, the need to be running parallel with the sides 25mm in, if someone could tell me how/or what function I should be using I would be very grateful
I have attached the file and also I have attached a photo of the physical template im working off.
Any comments or suggestions would be greatly appreciated.
Matt
A1.dxf
(28.1 KiB) Downloaded 301 times
Re: aligning holes
Post by Husky » Wed Sep 02, 2015 7:39 am
Hello Matt - welcome to the forum!
aklweld wrote:Hi
im having a bit of trouble drawing the holes I need on the attached part, I have been able to do the vertical and horizontal ones but I cant figure out how put the holes on the angled section of the job, the need to be running parallel with the sides 25mm in, if someone could tell me how/or what function I should be using I would be very grateful ...
For the 25 mm offset I would use the Modify tool "Offset with distance",
Then I would copy one hole (circle) to the clipboard what brings me into the position to use the "Paste along entity" tool.
What do you think - will that help?
aklweld
Re: aligning holes
Post by aklweld » Fri Sep 25, 2015 12:45 am
that was exactly what I needed, thanks husky
cheers
matt
