DXF spline curve help
AesculusMaximus
Post by AesculusMaximus » Sun Sep 27, 2015 9:29 am
Hi
Im trying to write a dxf programmatically but am having problems with a spline. I need to use fit points rather than control points as the curve needs to actually go through the specified points. Does anyone have an example?
My code so far (not working)
SPLINE
8
mylayer
70
11
71
2
74
4
12
0
22
1
32
0
13
1
23
0
33
0
11
-12286.2742525
21
8637.96944549
31
0
11
-10286.2742525
21
5637.96944549
31
0
11
-12286.2742525
21
3637.96944549
31
0
11
-15286.2742525
21
5637.96944549
31
0
0
Re: DXF spline curve help
Post by andrew » Mon Sep 28, 2015 10:19 am
You can create a working example using QCAD:
- Draw a simple spline with known fit points
- Save as DXF
