dwg2maptiles on OSX
nigeSeeable
dwg2maptiles on OSX
Post by nigeSeeable » Fri Oct 16, 2015 2:19 pm
Hi all, I have just purchased QCad pro in order to use the 'dwg2maptiles' tool - however I am unable to figure out how to use this tool on my mac.
I have tried cd-ing to the installation on my mac's terminal and running
./dwg2maptiles -h
for starters but (probably obviously to those in the know :oops:) this hasn't worked and despite much searching and looking both on this forum and through google I have hit a brick wall. :!:
I have searched the forum but everyone else seems to know what they are doing and so don't need to ask how to use these command line tools :wink:
I am using QCad Professional 3.11.3.0 on the latest OSX (el capitan).
Any help in this matter would be brilliant. Thanks in advance
Re: dwg2maptiles on OSX
Post by andrew » Fri Oct 16, 2015 2:36 pm
Under Mac OS X, applications are bundled into so called Application Bundles. In the case of QCAD Professional, the application bundle is called "QCAD-Pro.app".
The command line tools of QCAD are located inside the application bundle under "Contents/Resources".
If you have installed QCAD Professional into your application folder, proceed as follows:
- Open the Terminal application
- Change into the /Application folder
cd /Applications
- Change into the QCAD-Pro application bundle:
cd QCAD-Pro.app/Contents/Resources
- Launch the command line tool, for example:
./dwg2maptiles -o ~/Desktop/flange ./examples/flange.dxf
This creates a folder called "flange" on your desktop with the rendered map data of the QCAD example file /Applications/QCAD-Pro/Contents/Resources/examples/flange.dxf
More information about the QCAD command line tools is available on our web site at:
http://www.qcad.org/en/qcad-documentati ... line-tools
nigeSeeable
Post by nigeSeeable » Fri Oct 16, 2015 3:21 pm
Thank you Andrew - perfect
