Pattern Size File
wayne67
Pattern Size File
Post by wayne67 » Wed Dec 23, 2015 3:05 am
Is there a size limit for the size of a a patterns file?
This file is much larger than the files that came with
Qcad.
stackedstone.pat
(1.08 MiB) Downloaded 336 times
Re: Pattern Size File
Post by andrew » Wed Dec 23, 2015 10:05 am
There is no size limit but there is a time out for rendering hatches under Edit > Application Preferences > Graphics View > Appearance > Timeout for hatch rendering
I'd certainly not recommend using a 1MB hatch pattern definition with QCAD. Note that it will also blow up your DXF files.
