Application Preference
tkmbi
Post by tkmbi » Mon Mar 14, 2016 7:51 am
we like to prepare a set of settings like take out some command out of the menu, to give our service people
at the start and for training, a setting where only the basics are there.
Is there a XML or INI File, after we have made a basic setting for us, which we can copy then after installation, so everybody have the same setting ?
Thanks in advance :)
Re: Application Preference
Post by Husky » Mon Mar 14, 2016 8:27 am
Hi tkmbi,
tkmbi wrote:Is there a XML or INI File, after we have made a basic setting for us, which we can copy then after installation, so everybody have the same setting ?
QCAD will store automatically all settings in the qcad3.ini. Use this ini for all other QCAD application.
This link will help you to locate the qcad3.ini regarding to the OS:
http://www.qcad.org/en/qcad-documentati ... leshooting
