Hi, I have Spline 12345 with length = 814.8
And now, I need find node 6 on this Spline with distance from 2 to 6 (length 2 3 6) = 350, but I can't find any way to do this. Help me, please
Find node on Spline by distance
- spline_node.dxf
- (104.61 KiB) Downloaded 299 times
Re: Find node on Spline by distance
You can snap to a point with a given distance to an end point, but not to a point with a given distance from a spline node on the spline.
Breaking up the spline into bezier segments will bring you closer to your goal:
Misc > Modify > Convert Splines to Bezier Segments
With some simple additions and subtractions, you should be able to find the point then.
