I am using Windows 10 on Qcad3. how do I hatch this object that is circled?
Also I used the modification toolbar using the round button and got this and I can't get rid of the lines.
Len
Help with Hatching
Re: Help with Hatching
Only unambiguously defined, closed shapes can be filled using the hatch tool.
See also:
http://qcad.org/doc/qcad/latest/referen ... /doc/Hatch
If you cannot solve the problem, please attach the DXF file you are working on, so we can help you efficiently. Thanks.
See also:
