Decimal separator
Ozocker87
Decimal separator
Post by Ozocker87 » Fri Aug 05, 2016 9:20 pm
How can I set the decimal separator to a comma for dimensions?
Re: Decimal separator
Post by Husky » Fri Aug 05, 2016 11:27 pm
Hi Ozocker87 - welcome to the forum.
Ozocker87 wrote:How can I set the decimal separator to a comma for dimensions?
Check this out:
Menu: Edit/Application Preferences/General/Coordinate Format/Decimal Point
Ozocker87
Post by Ozocker87 » Sat Aug 06, 2016 8:20 am
Hiya Husky. Thanks for the reply, mate. The method you've described seems to alter the way you enter co-ords in the command box, but not how the numbers on dimensions are displayed. :cry:
EDIT: I should clarify that it's the dimension labels I'm trying to alter, not the input method.
Moderator
Post by Clive » Sat Aug 06, 2016 12:11 pm
Ozocker87 wrote:EDIT: I should clarify that it's the dimension labels I'm trying to alter, not the input method.
Hello Ozocker87
Do you need to work with a metric set up or an imperial set up. Working with comma's usually dictates an imperial set up.
Drawing units and Measurement System can be changed in the Application preferences (changes that affect all new drawings) or Drawing Preferences (for current drawing only) dialogs.
Moderator
Post by Clive » Sat Aug 06, 2016 1:44 pm
I guess if you want to make a 'one off' change (...and I'm guessing this would not be the case!) you could change the label properties for a selected dimension using the property editor!
One off change to dimension label.png (19.92 KiB) Viewed 4192 times
Post by Husky » Sat Aug 06, 2016 5:06 pm
Hi Ozocker87,
could you please give us some kind of example what you have in QCAD and what your goal is to achieve in QCAD. Thanks.
