PDF generated are black/white
Glooman
Post by Glooman » Mon Aug 29, 2016 9:27 am
Can you please help me with this?
Even I'm working wih layer in color, when I export to PDF it's generated in B/W. Can't find advenced menu when exporting to configure PDF format: resolution, layer management, etc
Thank you and sorry if this question was answered previously. I didn't find it in the forum.
Emil
Moderator
Re: PDF generated are black/white
Post by Clive » Mon Aug 29, 2016 10:05 am
Hi Glooman
Try this:
1.Go to print preview first - Main menu > File > Print preview
select print preview.png (16.46 KiB) Viewed 3743 times
2.Select 'Full Colour Mode'
select full colour mode.png (17.27 KiB) Viewed 3743 times
Let us know if this does the trick.
Glooman
Post by Glooman » Tue Aug 30, 2016 1:23 am
Thank you for your response.
It doesn't work.
Here you have a capture with the version we bought:
*** sorry but can't paste the graphic capture (don't know why) ***
ok we bought the Qt version 5.5.1 x86_64 version 3.15.5.0 (3.15.5)
and the fact is that when we enter in File>Print Preview, we get a drawing image in color but, when I press the button PRINT or PDF the drawing turns B/W. If I press Store in PDF anyway. the PDF is also generated in B/W.
so....
Help!
*** we work with W7 professional x64b
Post by andrew » Tue Aug 30, 2016 8:08 am
Glooman wrote:*** sorry but can't paste the graphic capture (don't know why) ***
You can use the "Upload attachement" feature below to attach images, drawing files, etc.
Glooman wrote:ok we bought the Qt version 5.5.1 x86_64 version 3.15.5.0 (3.15.5)
so....
Help!
Please do attach or e-mail the drawing file (DXF/DWG), so we can help efficiently, thanks.
