[solved] Select Entity
Gerardf
Post by Gerardf » Sun Sep 04, 2016 1:28 am
I just purchased QCAD. Many years ago (probably 20) I suspect I had something very similar that was pretty useful. My new version is Version: 3.15.5.0 (3.15.5)
One problem I have is the Select function doesn't show the Select Entity function.
Any thoughts on this?
Re: Select Entity
Post by Husky » Sun Sep 04, 2016 2:42 am
Hello Gerardf - welcome to the Forum!
Gerardf wrote:... One problem I have is the Select function doesn't show the Select Entity function.
You mean to select single Entity's? If yes, just click with the left mouse button on the entity which has to be selected. If you need do select a couple of them press the CTRL key (and keep pressed) on your Keyboard or use a drag-box (rectangle selection) with your mouse cursor.
Was it that what you were looking for?
Gerardf
Re: Select Entity
Post by Gerardf » Sun Sep 04, 2016 7:55 am
I'm missing a step. For example, if I draw a line, then decide it's wrong, when I try to select the line in order to delete it, QCAD is still in the 'draw line' mode and tries to draw a new line.
Re: Select Entity
Post by Husky » Sun Sep 04, 2016 8:11 am
There are multiple possibility's to terminate a tool. My Qcad is set to terminate with a double right click with the mouse,
you can also try to work with the keyboard: 1 or two times "escape", or hit the letter Q twice ...
Gerardf
Re: Select Entity
Post by Gerardf » Sun Sep 04, 2016 11:12 pm
Thanks. I have it sorted now!
Re: Select Entity
Post by Husky » Sun Sep 04, 2016 11:50 pm
Gerardf wrote:Thanks. I have it sorted now!
Glad to hear that! :wink:
