I would like to create rectangular periodic tilings with a program, depending on a few adjustable parameters.
The program would be a doubly nested loop, with usual drawing command inside the loop.
Can this be done in the command line or by scripting Qcad ?
Where is the related documentation ?
Thanks.
periodic tiling programming
Re: periodic tiling programming
If the tiles are spread in a regular array with equal X/Y spacing and the tiles are all identical, you could simply use a block array (create a block, insert the block as an array of NxM block references).
If that is not the case, could you provide an example, screenshot, mockup, etc? Thanks.
here is a sample done with another software.
The tiling is periodic (regular) square.
Offsets (shifts) can be adjusted in order to minimize small cuts.
The question reduces to : how to create an array in QCad ?
Thanks.
Thanks.
- calepinage de cuisine.jpg (148.31 KiB) Viewed 4114 times
