How can I create a regular 2D array of an object in QCAD?
Array, matrix or pattern
From a QCAD user:
Re: Array, matrix or pattern
While you can of course simply copy an object several times using an equal distance, the most convenient way is to use a block array:
Creating a Block from Your Object
- Select the entities of your object
- Choose Block > Create Block from Selection
- Click a reference point
- Enter a name for your block (e.g. "Window", "Pillar", "Screw", etc)
Turning a Block into an Array
- Keep your block selected and turn it into an array (alternatively, insert your block as a new array)
- View > Property Editor
- Adjust the number of columns, rows and the column and row spacing:
If I create an array from a block, it behaves like a block itself: I cannot break the array without the initial block being exploded also. I thought it would be possible to break the array to keep the individual blocks generated ??
JJ Win7 pro-64
J-J: That would make a lot of sense, yes. You can patch your version to explode block arrays into individual block references:
https://raw.githubusercontent.com/qcad/ ... Explode.js
This file replaces file scripts/Modify/Explode/Explode.js of your QCAD installation. This should be considered experimental. Please back up the original Explode.js in case there are any problems.
Hi Andrew,
I replaced the script and on the same test, that seems to work OK
JJ Win7 pro-64
Excellent, thanks for the feedback. This will very likely be the new behavior of the explode tool for the next release.
