When I measure the distance between 2 points the measurement is displayed in feet and inches...eg. 2' 8". I want qcad to display the measurement as 32". How do I that?
[solved] Change units from feet & inches to just inches
Re: Change units from feet & inches to just inches
Nevermind I found it. Under label format I changed it from engineering to decimal.
