Has anyone tried exporting an SVG and importing to Tinkercad? I'm getting two odd problems; first the size of the drawing is completely different. Its scaled correctly but about 4x larger in each dimension. Not a huge deal but I don't want to keep resizing things when they should both be operating in a mm scale. Secondly it's not importing all the shapes. Below is a screen capture of the 2d drawing and the 3d rendering. One of the boxes is being recognized as a negative but the other shapes aren't.
Thoughts?
[solved] Tinkercad
[solved] Tinkercad
- tinker.png (645.11 KiB) Viewed 4198 times
- hatch.png (207.21 KiB) Viewed 4198 times
Re: Tinkercad
Hi ailstyn - welcome to the forum,
My cold guess would be: Explode everything in QCAD before you save it as a svg and try it again in Tinkercad.
Good luck!
I have no experience with Tinkercad but if it is able to read some of the shapes then you should figured out what are the differences between the readable and unreadable entities.ailstyn wrote:... Secondly it's not importing all the shapes. Below is a screen capture of the 2d drawing and the 3d rendering. One of the boxes is being recognized as a negative but the other shapes aren't.
Thoughts?
Good luck!
Re: Tinkercad
Progress! Sort of? Still searching, I'll update when/if I find the answer.
- exploded.png (1.51 MiB) Viewed 4192 times
Re: Tinkercad
It looks much better - not good - but better ...
I assume you have to explode it further - maybe 3(?) times ...
Re: Tinkercad
Exploding is not a good idea in this case. You'll have to keep your polylines intact to make sure they are exported as paths into SVG.
There are two ways to solve this: in QCAD or in an SVG tool such as Inkscape.
QCAD
Make sure that the outer polylines have a different orientation than the inner ones. For example, if the outer polyline is clockwise, all inner polylines must be counter-clockwise. To check the orientation of a polyline in QCAD, you can use the property editor and go from one vertex to the next. To reverse the orientation of a polyline, simply select the polyline(s) and choose Modify > Reverse.
Alternatively, you can simply import the SVG file into Tinkercad and then reverse all polylines which don't show up and generate the SVG again.
Inkscape
After exporting to SVG in QCAD, open the SVG in Inkscape.
- Select your geometry and choose Object > Ungroup
- Select all inner paths in Inkscape and choose Path > Combine
- Select the outer path
- Press shift and select the combined inner paths
- Path > Difference
You now have a single path consisting of an outer path and inner paths which are known to be holes (that's what the difference does).
This file should also import fine into Tinkercad.
QCAD
Inkscape
- Path > Difference
Re: Tinkercad
Success! Took a bit of fiddling to figure out how to use the vertex bits, ended up drawing the boxes as a polyline in a clockwise fashion rather than converting a box to one.
Thanks!
Thanks!
- vertices.png (916.09 KiB) Viewed 4175 times
Re: [solved] Tinkercad
.... looks good!
