QCAD 3.1 on Debian 7.1 problem [solved]
Postby serge » Fri Jun 21, 2013 8:40 am
I'm using a Debian 7.1 Linux box (kernel 3.2.0-4-686-pae #1 SMP Debian 3.2.46-1 i686 GNU/Linux)
I've downloaded the qcad-3.1.2-pro-linux-x86_32.bin binary, installed it without trouble but when trying to to run qcad, I got the following problem :
~/opt/qcad-3.1.2-pro-linux-x86_32$ sh ./qcad
./qcad-bin: /lib/i386-linux-gnu/i686/cmov/libc.so.6: version `GLIBC_2.15' not found (required by ./libQtCore.so.4)
./qcad-bin: /lib/i386-linux-gnu/i686/cmov/libc.so.6: version `GLIBC_2.15' not found (required by ./libQtGui.so.4)
./qcad-bin: /lib/i386-linux-gnu/i686/cmov/libc.so.6: version `GLIBC_2.15' not found (required by ./libQtNetwork.so.4)
Installed libc version is 2.13-38.
I think the origin of the problem is quite clear but the solution isn't.
any other solution than changing my distro (which I like)?
Thanks in advance,
Serge
serge
Re: QCAD 3.1 on Debian 7.1 problem
Postby hungerburg » Fri Jun 21, 2013 12:52 pm
A "have been" debian user here:
As far as I can tell, the only real solution would be for Andrew to compile the package on debian 7.1, which would probably incur some trouble, but at least qt-dev might be ok there.
On the other hand, would bringing your system to debian 8 testing count as "changing my distro"?
hungerburg
Senior Member
Postby josemarciosa » Fri Jun 21, 2013 9:22 pm
I have a same problem.
I am waiting a solution.
My System is:
- Debian 7 (wheezy) 64bits
- GLibC (Debian EGLIBC 2.13-38) 2.13
Is there a possibilities to compiling QCAD into debian 7, GLibC 2.13?
Thanks,
Marcio Araujo
josemarciosa
Postby hungerburg » Mon Jun 24, 2013 11:49 am
As explained in this post, at least the 32bit version of a previous point release works in Debian 7: viewtopic.php?p=8091#p8091 - the poster did not mention though, which one exactly....
hungerburg
Senior Member
Postby sphrases » Mon Jun 24, 2013 8:33 pm
I did following to get rid of the meassage about the glibc issue on Debian 7.1 x64 by
- download glibc-2.15 as "rpm" or "deb" package
- extract the folder lib64 (from rpm) or lib (from deb)
- copy the lib folder into the qcad directory
- add the folder to the start script: LD_LIBRARY_PATH="$DIR/lib:$DIR" "$binary" -style plastique "$@"
#!/bin/bash
# QCAD startup script
DIR=${0%/*}
binary="$DIR/qcad-bin"
# Many Linux distributions try to use a style plugin that
# is not available as 32bit version, links against another
# version of Qt or is otherwise incompatible. For this
# reason, this script forces the style to the integrated
# plastique style of Qt.
# The style may be changed here or removed to use the
# default style:
Problem: with glibc 2.15 I receive an segmentation fault:
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
Debug: RDxfPlugin::init
Debug: RHelpPlugin::init
Debug: RProScriptsPlugin::init
./qcad: Zeile 18: 12962 Speicherzugriffsfehler LD_LIBRARY_PATH="$DIR/lib:$DIR" "$binary"
Problem: with glibc 2.16 & 2.17 (newer versions) I receive error while loading shared libraries:
./qcad-bin: error while loading shared libraries: __vdso_time: invalid mode for dlopen(): Invalid argument
and related to the 2.16/2.17 error message I found this (seems to be a known bug in glibc :( )
Bug 14905 - error while loading shared libraries: __vdso_time: invalid mode for dlopen()
sphrases
Postby smf » Fri Jun 28, 2013 7:10 pm
Same problem with XUbuntu 10.04 LTS, where 3.0.0 works without any problems. I couldn't find a solution so far.
smf
Postby andrew » Fri Jun 28, 2013 7:20 pm
I'm currently testing with binaries compiled against glibc 2.13 with good results on most platforms so far.
smf: what glibc version does XUbuntu 10.04 have (you can usually just run the library: /usr/libc.so.6 or similar)?
Also, is it the 32bit or the 64bit flavor?
Postby smf » Fri Jun 28, 2013 8:13 pm
It's 32 bit, calling
/lib/tls/i686/cmov/libc.so.6
gives:
GNU C Library (Ubuntu EGLIBC 2.11.1-0ubuntu7.12) stable release version 2.11.1, by Roland McGrath et al.
Compiled by GNU CC version 4.4.3.
Compiled on a Linux >>3.2.0-23-generic<< system on 2012-11-15.
smf
Postby andrew » Wed Jul 03, 2013 12:09 pm
QCAD 3.1.3 is now available with 32bit and 64bit Linux packages that should work on any Linux distribution with glibc >= 2.11.1, including Debian 7, Debian 7.1 and (X)Ubuntu 10.04:
viewtopic.php?f=16&t=2475
Postby smf » Wed Jul 03, 2013 12:27 pm
now 3.1 works very well on XUbuntu 10.04 LTS, thank you so much!
smf
Postby josemarciosa » Wed Jul 17, 2013 5:04 am
Now QCAD 3.1 works very well on Debian Wheezy, thank you so much! :D :D :D :mrgreen: :mrgreen:
josemarciosa
