qcad-cam 3.29.1 - box selection lineweight issue
I think Qcad-cam pro version 3.29.1 has a new issue with lineweights when using box-select with screen based linetypes enabled.
See attached drawing and screenshot.
To reproduce:
load the attached drawing.
Auto-zoom, or zoom way out.
Turn on "Screen based linetypes"
Click and drag to select an area.
Note the line weight for the selection box is huge when screen based linetypes is enabled, but not when it's disabled.
Try various zoom levels with "Screen based linetypes" on and off
I don't recall screen based linetypes affecting this on previous versions of Qcad
Is there a way to make box-select ignore screen based linetypes?
To reproduce:
- Planks.dxf
- (596.55 KiB) Downloaded 225 times
- Planks.dxf - QCAD_005.png (171.74 KiB) Viewed 2927 times
Re: qcad-cam 3.29.1 - box selection lineweight issue
From the looks of it I think that you are right.
Probably the same sort of issue that is reported for the info tools: https://www.qcad.org/rsforum/viewtopic. ... 368#p43368
It should not and no there is no reason to.
Are you using a high resolution display?
https://github.com/qcad/qcad/commit/d04 ... 12a934afb7
Or it has to do with the porting to the new graphics view.
The red outer contour has a pixel based width and that requires it to be scaled according the view depth.
Something similar is required with the info tools.
Over to Andrew.
https://qcad.org/bugtracker/index.php?d ... sk_id=2516
Seems to be fixed:
https://github.com/qcad/qcad/commit/e1e ... 078c3be36c
https://github.com/qcad/qcad/commit/1ba ... 945fe4e07b
Version is updated to 3.29.2.0 ... 9min ago
Looks like Window Zoom also has the same or similar issue, bit it's only noticeable at very high zooms.
Doesn't warrant a revision IMO, more of an FYI
To reproduce:
Draw a 1 mm square
Enable Screen Based Linetypes
Use Window Zoom to repeatedly zoom in on the 1 mm square
Observe how the selection box's line width increases with each zoom until it becomes an enormous blob
qc 3.29.2
Mint 21.2
To reproduce:
Draw a 1 mm square
qc 3.29.2
Mint 21.2
Ifso, then the issue is not tackled where it occurs.
For how far that I understand it:
The majority of thing on screen are scaled representatives.
Or in screen-based, or in real size ... Rendered one way or the other way.
Adding something pixel based would introduce a kind of items to be rendered differently.
But if that is added so that it would look a pixel wide then there is no difference in how to render it.
Pixel based things, usually temporary auxiliary things, are then added so that it counteracts the final rendering.
Before the box selection border always looked 1 pixel wide, or continuously and filled blueish, or dashed and filled greenish.
But high zoom in correlation with fixed tolerances always has the Math against it.
This is your 1x1unit square at the origin, screen-based, with a selection box under 3.27.6.0 ... Remark the overshoot left-high.
There is no difference when turning of screen-based apart from the fact that the screen is totally filled with the width of the lines (0.25mm(ISO)).
As if my background turns white but in reality it are the things in the foreground that are displayed in white.
This is the main reason why screen-based linetypes exits.
If I zoom in even further then the border glitch may become a horizontal line spanning the entire screen.
Please try to mimic this example and post a screen grab of how that is visualized for you.
IMHO: We can zoom out for an overview or zoom in for details and that should not affect the selection border.
The issue was introduced with the Qcad version 3.29, that's why you're not seeing it in 3.27.6
Here is the screen grab of a window zoom with Screen Based Linetypes enabled.
With Screen Based Linetypes disabled, the selection box is 1 pixel wide, as it should be.
I am quite sure this is part of the same Box Select issue.
Here is a link to a video if that's helpful. This is a window zoom, first with screen based linetypes disabled, then with it enabled.
https://drive.google.com/file/d/1Q6UhAF ... sp=sharing
Thanks for reporting, although it doesn't mimic my example but there is clearly something not OK.
I also remark that your second example has chamfered corners.
And for some reason your QCAD instance has no rulers or you turned them off.
I plan to install a separate trial 3.29.2 version an take it from there.
Testing for all auxiliary shapes that I know of.
And for other reported issues with .29 ... .0/.1/.2 being fixed or not meanwhile.
I think maybe we're both getting confused. Perhaps I can simplify.
FS#2516 fixed a bug where the "Box Selection border", and "Measuring line Scale", were not pixel based width, but should be. This bug did not exist prior to version 3.29
I am reporting now, that "Window Zoom" also has the same bug. The Window Zoom border should also be pixel based width.
