no dimension trailing zeros
Postby aero » Thu Oct 06, 2011 5:00 pm
Hello, I'm using Ubuntu 11.04 and the 'Show Trailing Zeros' option for dimensions does not work. ie. '11.00' is always shown as '11' but '11.31' is shown correctly. I consider this a big problem.
aero
Postby andrew » Thu Oct 06, 2011 7:38 pm
Can you please double-check that you are changing the settings in the right place ('drawing preferences' and not 'application preferences').
Application preferences (Edit - Preferences) apply to the whole QCAD application and some default settings apply to new drawings.
Drawing preferences (File - Drawing Preferences) apply to the current drawing.
Postby aero » Fri Oct 07, 2011 3:46 pm
Okay you are right, I was changing the application preferences. Thanks
aero
