Viewports
Viewports
Postby bryank99 » Thu Oct 20, 2011 6:42 am
Am I missing something? The examples shown when selecting multiple viewports imply that the views printed are different in each viewport, however all changes to scale etc I make in one are simply set in the others. Should one not be able to move the "paper" to include the desired drawing as in version 2 and be able to set different scales in each viewport?
bryank99
Postby andrew » Thu Oct 20, 2011 8:22 am
If I understand you correctly, you associate viewports with printing to paper. However, there is no such relationship. Viewports are a feature for the display. With multiple viewports, you can zoom in to different features of your drawing at once. Viewports have no influence on printing to paper or exporting to PDF.
Viewports
Postby bryank99 » Thu Oct 20, 2011 8:01 pm
Thanks to Admin. Your answer clears up my question. I was associating viewports with those used in AutoCAD for printing purposes. The viewports as used here will prove to be really useful, what a pleasure!
bryank99
