QCAD 3 BETA 3, Issues
Postby koosjr » Sun Oct 23, 2011 6:47 am
OK, Version Beta 3 installed on both Windows and Linux.
Windows Bugs:
1. For some reason on the Window machine, the snap toolbar buttons are doubled for all functions. I therefore have two buttons for each type of snap and cannot access the bottom snaps unless I undoc the toolbar.
For some reason, this is still fine in the Linux Beta 3. Single buttons like always.
Issues on Both:
1. When selecting the Scissors function, it deactivates after the cut is done. One can therefore not continuously select lines and cut it at the selected point. Each time the function has to be activated from the start.
Beta 3 seems faster in opening drawings than Beta 2.
koosjr
Postby andrew » Sun Oct 23, 2011 11:38 am
Re: QCAD 3 BETA 3, Issues
Postby Husky » Sun Oct 23, 2011 7:52 pm
koosjr wrote:1. For some reason on the Window machine, the snap toolbar buttons are doubled for all functions. I therefore have two buttons for each type of snap and cannot access the bottom snaps unless I undoc the toolbar.
@koosjr:
I have seen this behavior after the Beta3 was installed in the same (already existing) subdirectory from the Beta2.
I reinstalled the Beta3 in a new subdirectory and everything was nice working ... :wink:
Postby andrew » Sun Oct 23, 2011 8:02 pm
Husky: thanks for the hint.
It's definitely a good idea to uninstall older versions before installing a new one.
I'm checking if this could be done or at least encouraged automatically when the installer is run.
Postby J-J » Sun Oct 23, 2011 10:01 pm
I found the same problem of double entries in the SNAP menu. I tried your suggestion of uninstalling. The fresh install is now allright for that matter.
J-J
Moderator
cron
