Moving dimension lables
Brass Monkey
Postby Brass Monkey » Wed Nov 09, 2011 2:28 pm
Previously bought up but apparently a bug, not settings -
I can move dimension lables in dimensions above a few units in size, but for any dimension I put in that has a size small enough that the lable appears outside the limits of the dimension the lable is locked and won't go anywhere. This makes things fiddly where small details are concerned.
Lables can be moved in any instance where the dimension figure snaps between the dimension lines.
Thanks in advance :)
Postby andrew » Wed Nov 09, 2011 2:54 pm
Thanks for the followup. Task has been opened:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=379
Return to “QCAD 3 Troubleshooting and Problems”
