changing an item's layer
Postby tyke » Thu Nov 10, 2011 9:12 am
I tried to change the layer an item was on. This is possible if the recipient layer is visible. If it was hidden the item was not transferred.
tyke
Postby andrew » Thu Nov 10, 2011 10:02 am
This is intended. Hidden layers are generally not available to draw on since drawing on a hidden layer gives you no visual feedback. See also warning in command line history when trying to do so.
I do realize that in this special case it might be inconvenient. Task:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=383
