QCAD3 RC1 issue opening existing file
cmcgrath5035
Postby cmcgrath5035 » Sun Nov 13, 2011 2:08 pm
I have a file created with QCAD 2.2 that I have tried with 3.0B3 and it opened fine. I did not test there extensively.
I just downloaded 3.0RC1, and when I open the file some parts of a block I use from the Library (an A3 template) don't scale correctly, while other parts do.
I was "just learning" blocks when I made the edits, so may have done something incorrectly, but 2.2 and 3.0B3 were OK with it.
If you want to look at the file, let me know.
Postby andrew » Sun Nov 13, 2011 8:06 pm
Yes, please send the file to info@ribbonsoft.com if possible for testing, thanks.
Brass Monkey
Postby Brass Monkey » Wed Nov 23, 2011 1:12 pm
I have this problem too, also when scaling a template as a group or object rather than a block. The text components do not scale at all well and lose their position relative to the lines.
Postby andrew » Wed Nov 23, 2011 1:15 pm
It's a known problem and fixed for the next release:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=385
Return to “QCAD 3 Troubleshooting and Problems”
Users browsing this forum: duccoder and 2 guests
