QCAD3 RC2 Issue copy with reference (maybe)
cmcgrath5035
Postby cmcgrath5035 » Fri Dec 16, 2011 3:56 pm
I select several entities, the select edit-copy with reference
I don't see a prompt to enter reference like ver 2.2 had, but if I just enter 0,0 in the command area it does seem to work.
Likewise, when I paste it on a different layer, there is no prompt to enter reference, but entering 0,0 does give the correct result.
Perhaps I am not reading the bottom row of the window properly?
Postby andrew » Fri Dec 16, 2011 4:45 pm
I've posted a bug report:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=436
Note that the tools work properly but they do not change the command line prompt as expected.
Return to “QCAD 3 Troubleshooting and Problems”
