Library Browser not available.
Postby bearhawk426 » Sun Dec 25, 2011 5:11 pm
I have installed QCAD 3.0 RC2 in Kubuntu 11.10 (same as Ubuntu). I installed using the RC2 .bin file. Application starts and runs as expected except for the Library Browser. If I click on the icon for the Library browser I get the following error message:
Plugin LibraryBrowser: cannot connect to DB.
Driver error: Error opening database
Database error: unable to open database file
Database file: /home/jim/.config/RibbonSoft/library_3_0_0_Beta.db
Library browser will not be available.
The only file in the /home/jim/.config/RibbonSoft/ directory is QCAD.ini. The file library_3_0_0_Beta.db does not exist anywhere under my home directory. Do I need to generate this file somehow?
Thanks,
jim
bearhawk426
Postby andrew » Mon Dec 26, 2011 7:31 pm
No, the data base should be created and updated automatically. We'll look into that:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=441
