Library empty
Library empty
Postby saulos » Fri Jan 27, 2012 10:45 pm
Hi , I just installed R2 on my MAC with Lion 10.7.2.
But the library is empty ??? :(
how do I fill it ?
Thanks.
saulos
Re: Library empty
Postby Clive » Sat Jan 28, 2012 11:28 am
saulos wrote:Hi , I just installed R2 on my MAC with Lion 10.7.2.
how do I fill it ?
Thanks.
Hi Saulos and Welcome
Have you upgraded from version 2 or is this a new install?
Have you got any of the pre-installed blocks in the Library browser - look in system files folder (in library browser) -is there any thing there at all , like a small selection of blocks?
Or are you asking how to create and save blocks to the library?
Regards
Moderator / Drawing Help
Postby saulos » Sat Jan 28, 2012 1:06 pm
Hi Clive,
I installed the demo version to test the product, then I decided to buy it and I used the AppCleaner to remove the demo.
At this point I installed the regular version and I find that the library is empty as opposed to the demo version where I have see many different object .
Thanks for the quick answer ;)
saulos
Postby Clive » Sat Jan 28, 2012 2:22 pm
saulos wrote:Hi Clive,
Try uninstalling/clean up/ then reinstall to a different directory.
Postby saulos » Sat Jan 28, 2012 7:44 pm
Thanks I found the problem, it's pointing to the
QCadTrial.app\Library
wich is empty
But how Can I change the path for the library ??
saulos
Postby Clive » Sat Jan 28, 2012 9:39 pm
saulos wrote:Thanks I found the problem, it's pointing to the
wich is empty
Did you re-install the entire program to a different directory?
Postby saulos » Sat Jan 28, 2012 9:48 pm
no , no option on mac to choose the dir :(
saulos
Postby saulos » Sat Jan 28, 2012 9:59 pm
SOLVED
Thanks a lot for your help :D
It was very simple indeed :)
I had to open the library preference and delete the wrong reference, then close and reopen it and it recreated all the references ;)
8)
Have a good weekend my friend !
saulos
Postby Clive » Sat Jan 28, 2012 10:18 pm
saulos wrote:SOLVED
8)
No problem saulos
It sounds as if you worked this one out for yourself -well done .I have Windows 7-64 on the desktop and I work in Linux/Ubuntu on my laptop so I don't know mac at all!. Anyway likewise enjoy the rest of your weekend too. :D
