Library empty
Posted: Fri Jan 27, 2012 10:45 pm
by saulos
Hi , I just installed R2 on my MAC with Lion 10.7.2.
But the library is empty ???
how do I fill it ?
Re: Library empty
Posted: Sat Jan 28, 2012 11:28 am
by Clive
saulos wrote:Hi , I just installed R2 on my MAC with Lion 10.7.2.
how do I fill it ?
Hi Saulos and Welcome
Have you upgraded from version 2 or is this a new install?
Have you got any of the pre-installed blocks in the Library browser - look in system files folder (in library browser) -is there any thing there at all , like a small selection of blocks?
Or are you asking how to create and save blocks to the library?
Regards
Posted: Sat Jan 28, 2012 1:06 pm
by saulos
Hi Clive,
I installed the demo version to test the product, then I decided to buy it and I used the AppCleaner to remove the demo.
At this point I installed the regular version and I find that the library is empty as opposed to the demo version where I have see many different object .
Thanks for the quick answer
Posted: Sat Jan 28, 2012 2:22 pm
by Clive
saulos wrote:Hi Clive,
Try uninstalling/clean up/ then reinstall to a different directory.
Posted: Sat Jan 28, 2012 7:44 pm
by saulos
Thanks I found the problem, it's pointing to the
QCadTrial.app\Library
wich is empty
But how Can I change the path for the library ??
Posted: Sat Jan 28, 2012 9:39 pm
by Clive
saulos wrote:Thanks I found the problem, it's pointing to the
wich is empty
Did you re-install the entire program to a different directory?
Posted: Sat Jan 28, 2012 9:48 pm
by saulos
no , no option on mac to choose the dir
Posted: Sat Jan 28, 2012 9:59 pm
by saulos
SOLVED
Thanks a lot for your help
It was very simple indeed
I had to open the library preference and delete the wrong reference, then close and reopen it and it recreated all the references
Have a good weekend my friend !
Posted: Sat Jan 28, 2012 10:18 pm
by Clive
saulos wrote:SOLVED
No problem saulos
It sounds as if you worked this one out for yourself -well done .I have Windows 7-64 on the desktop and I work in Linux/Ubuntu on my laptop so I don't know mac at all!. Anyway likewise enjoy the rest of your weekend too.
