Missed extension line in dimension
Posted: Wed Feb 22, 2012 10:39 am
by ostene
Hello
One of the extension lines is missing in drawing dimension of a part..
Have I did something wrong?
Using Fedora-12
I use latest version of QCAD.
ostene
Re: Missed extension line in dimension
Posted: Wed Feb 22, 2012 11:48 am
by Clive
ostene wrote:Hello
Using Fedora-12
ostene
Which dimension option is not working for you -Aligned dimension, Linear, Rotated etc..?
Drawing dimension
Posted: Wed Feb 22, 2012 12:40 pm
by ostene
The problem was with horizontal and vertical dimension.
ostene
Extension lines problem
Posted: Wed Feb 22, 2012 1:08 pm
by ostene
Sorry, it is my fault in clicking wrong sequence.
I am new to Qcad.
Can administrator please remove this poll!
ostene
Re: Extension lines problem
Posted: Wed Feb 22, 2012 1:40 pm
by Clive
ostene wrote:Sorry, it is my fault in clicking wrong sequence.
I am new to Qcad.
ostene
ostene -I wouldn`t worry about it, I make QCAD mistakes all the time!
Posted: Thu Feb 23, 2012 9:30 am
by ostene
I like QCAD more and more as I use it
and become more trained.
The mistake was done because I was
thinking the Microsoft way (fuzzy logic) of doing it.
It is better to use clear logic thinking when
working with QCAD and the work will go smooth.
In this case click on "from liine" and then on
"to line" and at last position the dimension line
and make the third click. Done.
Thanks for QCAD
ostene
