Drawing file size
Drawing file size
Postby MiHeGo » Thu Apr 26, 2012 4:16 pm
The first drawing had a size of 819 Kb in QCAD 2 and now 1.584 Kb after only one action : show all layers. Nearly twice the size !
Re: Drawing file size
Postby andrew » Thu Apr 26, 2012 4:17 pm
This has nothing to do with the modification but with the different file format version that is being used by default in QCAD 3. QCAD 3 uses DXF / DWG R2012 by default which supports for example true colors and other things that DXF R12 doesn't.
Return to “QCAD 3 Troubleshooting and Problems”
Users browsing this forum: Yahoo [Bot] and 1 guest
