dimension labels <>
dimension labels <>
Postby ts232 » Mon Aug 20, 2012 10:03 pm
in 3.0, I have not been able to figure out how to add the <> to my dimension labels to put a " inch indicator after the dimension, as I was able to do in the 2.X edition. can't find anything about it in the docs either. help? thanks!
ts232
Re: dimension labels <>
Postby Husky » Tue Aug 21, 2012 7:25 am
Hello ts232,
instantly during the dimension generation in the Option Box ...
Husky_Postfix Option.png (30.69 KiB) Viewed 2687 times
... or you can select the dimension and edit it in the Property Editor window:
Husky_Postfix Toolbox.png (15.03 KiB) Viewed 2687 times
Postby andrew » Tue Aug 21, 2012 8:23 am
Husky, thanks for the explanation and screenshots!
I only have one small addition: one can also right-click into these text fields and choose "Insert Symbol" in the context menu that pops up. This might be convenient if you don't remember the code for measured value (<>) or also stacked text (\Supper^lower;). The context menu also offers some commonly used symbols for diameter, square, plus/minus, etc.
Postby ts232 » Tue Aug 21, 2012 2:37 pm
thank you both for your very helpful replies. I am loving the new qcad 3!
ts232
Users browsing this forum: No registered users and 5 guests
