Can not open DXF-File
Manfred
Postby Manfred » Wed Aug 22, 2012 3:49 pm
I attached a file, which I can not open with QCAD. With OpenOffice and AutoVue I can open the file. QCAD opens the file as "empty" sheet. I do not get any error messages. What can I check to resolve the problem?
Manfred
Head of the File:
0
SECTION
2
HEADER
9
$ACADVER
1
AC1009
9
$INSBASE
10
0.0
20
0.0
30
0.0
9
$EXTMIN
10
-1
20
-1
30
-0.5
9
$EXTMAX
10
5.5
20
5.86602540378444
30
5.5
9
$UCSORG
10
0.0
20
0.0
30
0.0
9
$UCSXDIR
10
1.0
20
0.0
30
0.0
9
$UCSYDIR
10
0.0
20
1.0
30
0.0
9
$CLAYER
8
0
9
$SHADEDGE
70
3
0
ENDSEC
0
SECTION
2
TABLES
0
TABLE
2
LTYPE
70
2
0
LTYPE
2
CONTINUOUS
70
0
3
Solid line
72
65
TestRibbonSoft.dxf
(41.02 KiB) Downloaded 233 times
Re: Can not open DXF-File
Postby andrew » Wed Aug 22, 2012 3:58 pm
Thanks for your report.
The file contains only three dimensional objects (type FACE).
QCAD does not import 3D objects as it is a 2D CAD solution.
If you let me know what you are trying to do with that file in QCAD, I'm happy to be of further assistance or work on a solution (e.g. import flattened faces).
Manfred
Postby Manfred » Thu Aug 23, 2012 7:40 am
Thank you for your replay.
It is new to me that DXF can contain 3D-data. I like to get a 2D contour of the top view to make a measurement drawing for the electical test points. In this case it seems not posible to this, because I cannot do any configurations for the output of the 3D-ECAD system.
Best regards
Manfred
Return to “QCAD 3 Troubleshooting and Problems”
Users browsing this forum: Baidu [Spider] and 2 guests
