Invalid Symbol Table Name
Postby pdimick » Sun Nov 25, 2012 3:32 am
An error message box appears suddenly "WARNING Invalid Symbol Table Name" The file then cannot be saved and all data is lost. It is occurring in a simple two layer dxf drawing with two layers and was started as a new file. Could newly created library items be causing a problem.
Thanks,
Paul
pdimick
Re: Invalid Symbol Table Name
Postby andrew » Sun Nov 25, 2012 9:03 am
Thanks for your report. Please indicate the exact version of QCAD you are using and your operating system name and version in all reports (see menu Help - About or QCAD Professional - About QCAD Professional (Mac).
Postby pdimick » Sun Nov 25, 2012 4:37 pm
Thanks. I am running Qcad 3.0.0 on Windows 8 Pro-- 32 bit
I am trying to replicate the bug on simple drawing. will keep you posted
pdimick
Postby andrew » Sun Nov 25, 2012 5:03 pm
This is likely a problem related to layer names (or block names if there are any non-standard blocks present).
Can you post the exact layer names you are using? Are there any special, characters in them such as special characters or international characters?
Postby pdimick » Sun Nov 25, 2012 6:14 pm
I've attached copies of the files in question:
Test1Walls.dxf
File is OK at this save pointt
(41 KiB) Downloaded 217 times
"Test1Wall.dxf" is using two layers: 0 and Floor Plan. The drawing is being saved without a problem.
However when I insert the library file "Door 24.dxf:
Test1Walls.dxf
I immediately get the error message "Invalid Symbol Table Name" At that point "Test1Walls" cannot be saved and must be discarded. The file is retained in the file directory but cannot be opened.
"Test1Walls" resides in C:\Users\Paul. "Door 24" resides in C:\Program Files\QCAD\Libraries\Default\MyBlocks
Thanks for your help.
Door 24 .dxf
(40.27 KiB) Downloaded 208 times
pdimick
Postby andrew » Sun Nov 25, 2012 7:38 pm
Please rename the library file from "Door 24 .dxf" to "Door_24.dxf" (note that two spaces have to be removed or replaced, one before the number 24 and one after it.
Basically, block names may not contain spaces. When creating blocks, QCAD prevents you from using spaces but when inserting a library item, the file name of the item is used as block name which produces this problem. Thanks for bringing this to my attention. This problem will be fixed in the next release. Most likely QCAD will simply replace spaces and the likes with underscores to create valid block names from file names.
Bug tracker:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=725
Postby pdimick » Mon Nov 26, 2012 2:45 am
I renamed the library file from "Door 24 . dxf" to Door24.dxf and there are no glitches, thanks.....but I do have other library files with spaces, e.g., "Window 36.dxf" that work well.
At least in Windows 8, I think the space between the file name and ".dfx" is the sole culprit, because I am able to use either "Door 24.dxf" or "Door24.dxf" equally well.. I am attaching the files hoping you get a similar result
Thanks for all your help
Door24.dxf
(40.27 KiB) Downloaded 202 times
Door 24.dxf
(40.27 KiB) Downloaded 193 times
pdimick
Postby andrew » Mon Nov 26, 2012 9:35 am
Thanks for your interesting findings. That is entirely possible that only the space at the end is the problem. I will look into that.
