Block management
Block management
Postby faber » Tue Jun 04, 2013 12:04 pm
I just downloaded 3 Beta2 but I have found out the same problem about the block management: it is unable to correctly manage a block when I double click onto the relative icon in the browser window. Simply I have to force the software to shut down. I hoped to see the 3 version fully usable on my Mac but...
Fabri
faber
Re: Block management
Postby andrew » Tue Jun 04, 2013 8:58 pm
faber wrote:I just downloaded 3 Beta2
I assume you mean 3.1 Beta 2.
faber wrote:but I have found out the same problem about the block management: it is unable to correctly manage a block when I double click onto the relative icon in the browser window. Simply I have to force the software to shut down. I hoped to see the 3 version fully usable on my Mac but...
What version of Mac OS X are you using? Does this happen for any drawing or just a particular drawing? Can you attach a drawing that has that problem? Thanks.
Postby faber » Wed Jun 05, 2013 8:17 am
I have just downloaded 3.1 and now, even a bit slowly, it can handles the blocks without freezing.
The file was an old file (I believe a 4-5 years old) created and modified by more than one software; surely it was created by Autocad, and it is in dxf.
Thank you.
faber
Users browsing this forum: Bing [Bot] and 3 guests
cron
