qcad-3.1.6 dwg2svg segmentation fault [solved]
Postby bilal » Wed Jul 31, 2013 9:18 pm
Hello there,
First i would like to congratulate on the work you have been doing. I have been looking for such solution when i come across QCad.
I tried to run qcad-3.1.6 in headless mode for converting dwg. I tried to execute dwg2svg script for converting dwg to svg. I executed
./dwg2svg ../budweiser.dwg
but i got a segmentation fault, and svg was not created successfully.
./qcad: line 18: 18567 Segmentation fault      LD_LIBRARY_PATH="$DIR" "$binary" -style plastique "$@"
Let me know if there is any document available for running QCad in headless mode.
I also tried compiling qcad, i cloned the latest code but got an error in that as well, i followed http://www.qcad.org/en/component/conten ... om-sources . The error was
g++ -c -m64 -pipe -O2 -w -D_REENTRANT -fPIC -DQT_WEBKIT -DQCAD_DLL -DPTHREADS -DHAVE_PTHREAD_H -DQCADECMAAPI_LIBRARY -DQT_NO_DEBUG -DQT_PLUGIN -DQT_WEBKIT_LIB -DQT_SCRIPT_LIB -DQT_SCRIPTTOOLS_LIB -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XMLPATTERNS_LIB -DQT_XML_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQDESIGNER_EXPORT_WIDGETS -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/qt4/QtHelp -I/usr/include/qt4/QtDesigner -I/usr/include/qt4/QtUiTools -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtXmlPatterns -I/usr/include/qt4/QtSql -I/usr/include/qt4/QtSvg -I/usr/include/qt4/QtScriptTools -I/usr/include/qt4/QtScript -I/usr/include/qt4/QtWebKit -I/usr/include/qt4 -I../../core -I../../core/math -I../../grid -I../../snap -I../../gui -I../../entity -I../../operations -I../../scripting -I../../stemmer -I. -Igenerated -Iadapters -I../../io/dxf -I../../spatialindex -I../../3rdparty -I/usr/X11R6/include -Irelease -o release/REcmaCircle.o generated/REcmaCircle.cpp
generated/REcmaCircle.cpp: In static member function ‘static QScriptValue REcmaCircle::touchesCircleInternally(QScriptContext*, QScriptEngine*)’:
generated/REcmaCircle.cpp:1838:22: error: ‘class RCircle’ has no member named ‘touchesCircleInternally’
make[4]: *** [release/REcmaCircle.o] Error 1
make[4]: Leaving directory `/work/dev-work/cad/qcad/src/scripting/ecmaapi'
make[3]: *** [release] Error 2
make[3]: Leaving directory `/work/dev-work/cad/qcad/src/scripting/ecmaapi'
make[2]: *** [sub-ecmaapi-make_default-ordered] Error 2
make[2]: Leaving directory `/work/dev-work/cad/qcad/src/scripting'
make[1]: *** [sub-scripting-make_default-ordered] Error 2
make[1]: Leaving directory `/work/dev-work/cad/qcad/src'
make: *** [sub-src-make_default-ordered] Error 2
I am willing to purchase but before that i want to make sure it fulfills my requirements. Add to that let me know does QCad supports latest dwg,dxf etc standards.
Wish: I am not sure if QCad supports this or not but can i get all the layers in separate svg and some how gets all the views (if presents).
Mirza Bilal
bilal
Re: qcad-3.1.6 segmentation fault
Postby andrew » Wed Jul 31, 2013 9:28 pm
bilal wrote:I executed
Thanks for your report.
Do you also get a segfault when trying to convert any other file, e.g. the example files included with QCAD in ./examples?
bilal wrote:I also tried compiling qcad, i cloned the latest code but got an error in that as well
Thanks, I've committed updated script wrappers.
Please note that checking out master is cutting edge and might not always work. Please check out the latest tagged version if you want to make sure that you have something stable.
Postby bilal » Wed Jul 31, 2013 9:56 pm
tried it with colors.dxf, and conversion worked.
Is it something like it does not support the file provided.
And is it possible to get separate svgs for each layer?
bilal
Postby andrew » Wed Jul 31, 2013 10:03 pm
bilal wrote:tried it with colors.dxf, and conversion worked.
That is possible. Maybe you can also try to load the file in the QCAD application or send me the file by e-mail for testing.
bilal wrote:And is it possible to get separate svgs for each layer?
Not out of the box. Using the script interface, it is certainly doable without too much effort.
Postby bilal » Thu Aug 01, 2013 9:16 am
I have sent you the file. The file opened properly but crashed with the same message on svg export.
Any pointers on qcad scripting where to start?
bilal
Postby bilal » Fri Aug 02, 2013 6:46 pm
Any update?
bilal
Postby andrew » Fri Aug 02, 2013 6:59 pm
I haven't had a chance to look into this problem yet. Probably next week. Thanks for your patience.
Postby bilal » Fri Aug 02, 2013 8:54 pm
Thanks Andrew, sor far QCAD looks good to me and will fulfill my requirements though i just need some pointers where to start with QCAD scripting and documentations etc.
bilal
Postby bilal » Sun Aug 04, 2013 9:30 pm
For anyone who could not find help, can look into http://www.ribbonsoft.com/doc/qcad/3.0/developer/_script_tutorials.html
bilal
Re: qcad-3.1.6 dwg2svg segmentation fault
Postby andrew » Tue Aug 06, 2013 2:51 pm
Postby andrew » Thu Aug 08, 2013 1:26 pm
This issue should be fixed in the latest QCAD release (3.2.0).
Re: qcad-3.1.6 dwg2svg segmentation fault [solved]
Postby bilal » Thu Aug 22, 2013 10:47 pm
Thanks Just tested it on 3.2.2, and it has been fixed.
bilal
