Moving/Copying Polylines
tukuyomi
Postby tukuyomi » Mon Aug 12, 2013 9:37 am
(I'm not really sure it's a bug, sorry for that. Also, I tried to write it on the Bug Report, and got a permission error on posting)
Please see the attachment or this image : black-ship.net/~tukuyomi/stuff/public/misc/move_poly.png
Try to move/copy the draw next to it:
CTRL+A; CTRL+SHIFT+C; CTRL+V, then check flip (horiz or vertical), the drawing is somehow strangely reversed.
QCAD 3.2 on Windows XP 32bits. If needed, I can test later on Linux 64bits.
move_poly.zip
(6.81 KiB) Downloaded 165 times
Moderator / Drawing Help
Re: Moving/Copying Polylines
Postby Clive » Mon Aug 12, 2013 10:18 am
tukuyomi wrote:If needed, I can test later on Linux 64bits.
This is definitely a bug, confirmed and tested on Linux Mint -64
paste, flip problem.png (23.79 KiB) Viewed 2218 times
Not sure why you cannot use the bug tracker ?
Report added:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=878
Postby Clive » Mon Aug 12, 2013 10:30 am
This seems to be a problem related to polylines containing arcs! I could be wrong but in my test case you can see the polyline on the left (2 lines, 2 arcs), then when copied/pasted and flipped the arcs get inversed!
paste, flip problem 2.png (1.42 KiB) Viewed 2214 times
Postby andrew » Mon Aug 12, 2013 11:08 am
Thanks. This problem is fixed for the next release.
For now, the workaround is to paste without flipping and use the mirroring tool afterwards.
tukuyomi
Postby tukuyomi » Mon Aug 12, 2013 12:47 pm
Wow, now that was quick :D
Thank you both clive and andrew !
Return to “QCAD 3 Troubleshooting and Problems”
