CreatingDrawing.js Failing from Command Line
wildspidee
Postby wildspidee » Wed Aug 28, 2013 4:03 am
I'm running the CreatingDrawing.js from the command line and it's throwing an error.
Call - ./qcad -autostart scripts/Examples/Tutorials/CommandLineTools/CreatingDrawing/CreatingDrawing.js
Error -
Warning: RScriptHandlerEcma::eval: script engine exception: "ReferenceError: Can't find variable: RDxfExporterFactory"
Warning: "<anonymous>()@scripts/Examples/Tutorials/CommandLineTools/CreatingDrawing/CreatingDrawing.js:27"
Warning: At least one uncaught exception:
Running on Mac OSX V 10.8.4
3.49 GHz Intel Core i7
16GB RAM
QCAD Pro 3.1.4.0
I didn't mess with the javascript, ran it stock from the QCAD install. Have I done something incorrectly or is there a problem with the script? Thanks for any help.
Re: CreatingDrawing.js Failing from Command Line
Postby andrew » Wed Aug 28, 2013 9:00 am
Thanks for the report.
Line 27:
RDxfExporterFactory.registerFileExporter();
is no longer necessary. Please delete that line and run the script the same way again.
wildspidee
Postby wildspidee » Wed Aug 28, 2013 3:37 pm
That did the trick! I've got a triangle.
Thank you Andrew.
Return to “QCAD 3 Troubleshooting and Problems”
